Case 430 question
Brian in Ohio
01-25-2004 06:42:27
My father and I have acquired a 1957 Case 430. My question is that on the serial number plate, it has the model number 441-L. Does that model number hold some significance? Is there different versions of the 430? I'm not as versed in the 30 series as I am the grey series, so I'm looking to get educated. Thanks in advance.
Gene Dotson
01-25-2004 15:10:12
 Re: Case 430 question in reply to Brian in Ohio, 01-25-2004 06:42:27
Brian; A 441-L would be a row crop gas engine with adjustable width axles and the "L" stands for low speed gearing... Gene
Brian in Ohio
01-25-2004 16:47:30
 Re: Re: Case 430 question in reply to Gene Dotson, 01-25-2004 15:10:12
Then the wide front end under now has been put under it by someone after it was originally sold? THe tractor currently has a loader on it, so I could see why it would be changed, but I'm wondering if I should change it back?
John Saeli
01-25-2004 10:28:24
Hey Brian: The 430 wasn't released until '60, so it's newer than you think. Yes, there were different styles. Different front axles, Direct drive or C-O-M, Gas or Diesel, Cat. 1 Flexible Hitch or Eagle Hitch.
Brian in Ohio
01-25-2004 10:47:08
 Re: Re: Case 430 question in reply to John Saeli, 01-25-2004 10:28:24
OK, it may be newer than 57, and I'll go get the serial number once it warms up a little. It is gas, has a wide front end, COM, and Eagle Hitch. It also has the exhuast running down and underneath the tractor. Is that common? What does the "L" in 441- L mean?
Dave
01-25-2004 17:51:48
 Re: Re: Re: Case 430 question in reply to Brian in Ohio, 01-25-2004 10:47:08
Is the loader a case loader??? I have been told by an old case dealer friend that the L stands for loader tractor, as come from the factory. I have a 511B-L
Brian in Ohio
01-25-2004 17:55:43
 Re: Re: Re: Re: Case 430 question in reply to Dave, 01-25-2004 17:51:48
I am not sure if it is a Case loader or not. I didn't see any markings on it that would tell me for sure.
