Model L Serial Number
dlp
01-24-2004 19:55:09
I brought home a model L & I'm not sure of the year. I've seen two different systems for I.D. & each are different. The serial number is 331380. What year is this? I believe it to be a 1930, but not sure. Thanks!
Dr Cy Kosis
01-25-2004 07:10:41
 Re: Model L Serial Number in reply to dlp, 01-24-2004 19:55:09
On a six digit serial, it's 1st and 4th digits minus 3. or in your Case 3xx3xx = 33-3 = 1930
The 2nd, 3rd, 5th and 6th digits (x31x80) tells you it was the 3,180th L series tractor produced that year.
All the six digit Case serials are this way.
The seven digits in 1936 and 1937 have two different formulas that depend on whether the first two digits begin with 42 or higher to know whether to use the six or seven digit formula. 1938 to early 1953 use the seven digit serial number system of first two digits minus 4.
Brian in Ohio
01-25-2004 04:25:59
1930 is correct.
