Case 500 diesel questions
Brent
01-24-2004 16:38:16
Slightly interested in a 500 diesel. I haven't looked at it, so I know nothing about them. I think the engine's stuck.
Is the 500 a rare tractor?
Are parts available?
What's the hp rating? Live hydraulics and PTO?
Southpaw
01-31-2004 14:27:30
 Re: Case 500 diesel questions in reply to Brent, 01-24-2004 16:38:16
I have my dads 500 engine tore down (engine had been full of water 20 years)in my shop. I would like to have it running by spring for the tractor shows this summer. Where can I find an engine kit for it? I heard they are expensive but I can't even find one. Any Ideas?
RobertTX
01-26-2004 06:01:14
One of the best sounding engines ever made. Six cylinder, 1300 rpm, compression around 15:1, makes a wonderful noise. Not rattly like newer diesels with higher compression ratio and higher rpm. As the guys said, a stuck one can be a little risky. If you are looking at the one on ebay, he said he can move it a little each way. Pictures show intake and exhaust uncovered, suspect water in one or more cylinders. Might be able to open compression release and pump most of it out.
Don L.
01-25-2004 06:26:55
They could be nice tractors, spendy to fix, heads crack, injection pumps are costly, the small flange sleeves were only used for about a year, noisy pinion drives are common, most fenders are the brakes, seat supensions are 4x4's, power steering leak, the frt ends shimmy in road gear. exhaust elbows all welded up. Hummm, that about covers it.
Don L.
GeneDotson
01-25-2004 03:52:47
Nebraska rated at 63.81 horsepower... Gene
caseman-d
01-25-2004 20:16:29
 Re: Re: Case 500 diesel questions in reply to GeneDotson, 01-25-2004 03:52:47
Gene,
Gene isn't that belt hp????
caseman-d
caseman-d
01-24-2004 22:27:56
The 500 was made 1953-1956, total of 5985 units made, depends on the serial number if you want to consider it rare. 1953=335, 1954=4300, 1955=450 and 1956=900. If the engine is stuck try to buy cheap, engine work can turn out to be expensive on these tractors. Might check for cracked heads, they had two head casting numbers so make sure all three are the same if ordering gasket set.
caseman-d
dctom
01-24-2004 18:13:27
made from 52 to 55 hp about 70 i think 377 engine live pto and hyd
