VAC leaking rockshaft
Red Tom
01-24-2004 16:21:33
This is my first Case restore. What should I look for with the oil leaking out of the control lever/right side of the Eagle hitch rock shaft. I want to fix it right. Also what do I use for oil. I've been using Transdraulic like IH hytran. My buddy uses 90w in his VAC with eagle hitch. Thanks, been here before and you guys are always helpful.
Joe (Wa)
01-24-2004 20:07:45
 Re: VAC leaking rockshaft in reply to Red Tom, 01-24-2004 16:21:33
There is a leak-off tube on the right side of the cylinder housing to convey minor piston leakage back to the torque tube. It may be plugged (grease?)and the oil is being forced through the right side rock shaft bearing when the lift is raised. May also have more leakby then the tube can handle.
As Sam#3 stated the other suspects are the lift & release valves. Check the cap on the relief valve in there also.
Joe
Sam#3
01-24-2004 17:50:17
Two possible causes:
1)The cylinder seal is leaking. The oil is leaking into the rockshaft housing and out past the shaft. There is no seal on the right side of the housing.
2)Either the control or release valves(or both) are leaking.
The low pressure hydraulic system calls for 20W engine oil above +70 degf., 10W +70-+32 degf., 5W below +32f.
Sam#3
01-24-2004 18:01:39
 Re: Re: VAC leaking rockshaft in reply to Sam#3, 01-24-2004 17:50:17
I should have said 'piston seal.' This may be a leather cup or and O ring, depending on the model of machine.
Jim
01-24-2004 18:55:23
 Re: Re: Re: VAC leaking rockshaft in reply to Sam#3, 01-24-2004 18:01:39
Well I think Sam#3 hit it on the head. I use Hytrans Plus, works good and keeps it quiet.
