Manifold heater question
Eddie in Ky
01-24-2004 14:33:07
I am replacing a bad manifold heater in an 885 DB. It has a "fuel line"? to it? Is it a fuel line, and if so how is it supposed to work? I can't find reference to it in an IT manual. How do I trouble shoot it, etc.
Thanks for any help,
Eddie
kyhayman
01-24-2004 15:39:00
 Re: Manifold heater question in reply to Eddie in Ky, 01-24-2004 14:33:07
That line runs from a tiny accumulator where the return line from the injectors go back into the tank. When you turn to 'heat' it heats a small coil spring which expands in the thermostart unit. As the spring heats it expands and pushes open a little ball which allows fuel to dribble onto the hot spring which ignites the fuel inside the mainfold. This burning fuel is then sucked into the combustion chamber to help ignite the fuel.
