case VAI hydraulics
Ben C
01-22-2004 07:45:23
Have a 52 case VAI with hydraulics, pump is located on right side of enginem control valve is located on right side of tube between trans and engine, does the hydraulics share the same fluid with trans and rear, there is a fill plug on left side of torque tubr as well as on top of trans, thanks.
mj
01-22-2004 17:57:39
 Re: case VAI hydraulics in reply to Ben C, 01-22-2004 07:45:23
The torque tube is the reservoir for the hydraulics and uses 20wt motor oil; the transaxle housing is separate and uses GL90.
