Rear light lense
BLMN
01-21-2004 13:45:08
Is anybody aware of a place to purchase a 4.5" lense for the rear light on a DC?
Terry
01-26-2004 13:43:51
 Re: Rear light lense in reply to BLMN, 01-21-2004 13:45:08
Good luck, I couldn't find them anywhere.
I found a couple last year but the guy wanted $50/each.
I looked into having a glass shop cut some but didn;t follow through.
I would maybe pay $15 or $20, but by using a generic seal beam and the tubing trick it works alot better, and if you use your tractor the lights work great a lot better then the bulbs!
Terry
G. L. Grumpy
01-21-2004 23:19:21
Try Korves Oliver. They just started carrying a new bunch of light parts, lenses and such that fit many brands. Yours don't need the red amplified part for a rear light and spot too does it? I have one on my MM, don't think I'ld ever find it new. It has a red back and smaller bulb on outside of sealed beam, with lense built in to back of bulb too for the red.
BLMN
01-22-2004 07:36:21
 Re: Re: Rear light lense in reply to G. L. Grumpy, 01-21-2004 23:19:21
Where can I get ahold of Korves Oliver?
C. Amick
01-21-2004 14:19:16
Is it 6 volt or 12 volt? I bought 4-inch 12 volt sealed beam lamps and made them fit the 6 volt housings on my Case 300 by splitting a piece of rubber tubing down one side and opening it up and siliconing it to the outer edge of the lamp. I used a 6-inch band clamp to hold the tubing in place until the silcone dried. The light rings hid the rubber tubing.
BLMN
01-21-2004 17:25:09
 Re: Re: Rear light lense in reply to C. Amick, 01-21-2004 14:19:16
12 volt the light works I am just looking for the glass lense.
