VC, change to 12 volt?
mike
01-21-2004 10:20:13
Has anyone changed a VC to a 12-volt system. What type or brand altenator did you use? What changes had to be made?
Jared Chaddock
01-23-2004 09:07:20
 Re: VC, change to 12 volt? in reply to mike, 01-21-2004 10:20:13
On my VC, I had the original Autolite generator rewound for 12V. That way, everything fits, and it looks original. Starts like a million bucks now. No matter what it never started well with 6v.
Gene Dotson
01-22-2004 15:06:52
Mike; My VC was converted to 12 volt by using a Ford truck generator from the late 50's. It already has the wide pulley to fit the VC belt and looks a lot more original than an alternator. Personally, I have found the 6 volt system to be adequate on all my tractors that are still using it. For battery cables I use #2 welding cable with 2/0 connector ends and solder all ends. Many times the starter button is burnt and corroded causing a lot of resistance. Try cranking the engine for a few seconds and then feel all cables and switches for heat. Whatever is hot needs to be cleaned or replaced. I am cheap and retired, so I spend more time than it is worth and dismantle starter buttons and clean them and makes a lot of difference in cranking speed... Gene
Terrance
01-21-2004 22:33:00
A GM altenator with internal regulator is pretty much the altenator of choice, they are cheap and plentiful and work about the best of any. The easiest to use is the one wire conversion, the altenator requires just the battery wire hooked to it to charge. A 10 gauge wire from the Altenator positive post connected to the battery side of the solenoid, a ground wire is also a very good idea. You can get these at most auto parts stores just ask for a GM one wire altenator,they were originaly a marine altenator. You will have to replace your 6 volt battery with a 12 volt battery that will fit in the battery box, if your tractor was positive ground you need to change the connections and make it negative ground. The small wires on your coil will need to be reversed, your coil will have a + screw and a - screw, the small wire on the - screw hooks to the distributor. If your tractor uses a wide belt then you will need to take the pulley from the generator and place it on the altenator. You can also use the standard GM/Delco altenator that came on most cars and trucks the wiring is a little more complex but still very easy, it requires just two wires, a short jumper wire, and a diode. Hope this helps Terrance
Mike
01-22-2004 05:32:03
 Re: Re: VC, change to 12 volt? in reply to Terrance, 01-21-2004 22:33:00
Thank you, that really helps me out.
Todd in MO
01-22-2004 05:01:30
Sure could't get a better answer than that!
