head gaskets on 730, 830
todd
01-20-2004 16:43:36
i have looked at an 830 and 730 case diesel tractors lately and noticed that the head gaskets on both of them were leaking. is this a trend in these model tractors?and if so is it just the diesels,the were both 1968,1967year tractors. any input would be apprieciated, thanks, todd
Glenn F.
01-20-2004 17:21:44
 Re: head gaskets on 730, 830 in reply to todd, 01-20-2004 16:43:36
Something to be said for proofreading. I meant to say either is not uncommon in the summer. Anytime the temp. is below 60 degrees the either better not be far away.
Glenn FitzGerald
01-20-2004 17:11:50
We had a 730 and 830 diesels for many years with no head gasket trouble. I have not heard of their having such problems. The only problem we had was winter starting. They are nearly impossible. Even with a high power block heater it's not easy. Either is not common in the summer. They both ran very well. Very economical.
turbo
01-20-2004 17:29:36
 Re: Re: head gaskets on 730, 830 in reply to Glenn FitzGerald, 01-20-2004 17:11:50
30 series head gaskets leaked oil at the corners of the heads. Case or the gasket manufacturer, developed a better gasket with grommets to solve this problem. We got tired of replacing gaskets to solve the leak, but the engine stayed clean. 70 series, improved engine, heads leaked just like 30 series. They did not put the grommets back in the new head gaskets. New batch of engineers??? Were they the gasket manufactures or Case's. The job was a lot more difficult with the 70 series hood. After we replaced those early head gaskets, the engines stayed clean.
