Substitute for Case TCH
David B
06-21-1999 12:24:08
What is a safe hydraulic fluid to use in the torque converter if Case TCH isn't available? I have to go about 100 miles to get TCH.
David
07-25-1999 20:19:26
 Re: Substitute for Case TCH in reply to David B, 06-21-1999 12:24:08
Dexron 3 is the only thing close, but it will not stand the heat of heavy loads. This is only acceptable in an emergency.Should be replaced with TCH asap. TCH is specially formulated for heat and loads. Dexron or c3 transmission fluid is only in the operators manual as an option because the government says you must list an alternate lubricant.
Roger
06-27-1999 20:23:10
David, our 830 has had auto. trans. fluid in it for years. Case recommends either auto. trans. fluid OR TCH. Mr Rudolph, read an owners manual on a case -o- matic, you might learn something.
Don Rudolph
06-25-1999 13:45:14
If you are using the oil for a Case-o-matic transmission, use TCH ONLY!!!
Don Rudolph
06-25-1999 13:45:08
john
06-23-1999 18:35:52
Case IH Hy-tran Plus
