Case L LA
dlp
01-19-2004 18:42:58
How much differeince is there in these two engines? Will the parts interchange?
Brian in OHio
01-19-2004 18:51:00
 Re: Case L LA in reply to dlp, 01-19-2004 18:42:58
The majority of the engines parts will interchange. I think there is a minor difference in the governor, but as fas as sleeves, pistons, etc., they will all swap out.
Allan C
01-19-2004 20:30:39
 Re: Re: Case L LA in reply to Brian in OHio, 01-19-2004 18:51:00
They are basically identical. There were running minor changes on the L. The L block didn't come with a starter boss until '37 or '38. The rocker arm oiling wasn't positive on the early L but later had a pipe added to feed oil up there. I think compression ratios went up a little too.
