Need Dozer Identified
Steve K
06-21-1999 07:32:48
Saw a small gas (4cyl) Case dozer that maybe should be sitting on my place rather than where it currently sits. I could not see a model # but I did get a # of G3000563C this number is on the frame on the left side next to the engine. Also, a casting # of ATC 30718 is on part of the track framework. The thing has a Terratrac 16693 cast on part of the Dozer that I think Identifies the dozer. Anyway any thoughts on what Model this thing is or the name of a book to look it up in?
peter baar
07-09-1999 06:41:18
 Re: Need Dozer Identified in reply to Steve K, 06-21-1999 07:32:48
Road Machinery Co., is looking to purchase one
Good used LH final drive for a Case 850B dozer
Per machine serial number 7078768
Final drive no. G101602
Please give me a call 602-256-5133 if you are able to Supply good used or rebuilt.
Pete Baar Manager Export Sales
Road Machinery Co.
Jerry Brown
06-22-1999 22:25:39
Sounds like you have a transitional Case back from the mid to late 50s. Case acquired American Tractor Co. (ATC)which built crawler tractors under the name Terratrac. Case did not then have a line of crawler tractors. I have heard the date of January, 1957 as the acquisition date. For a while thereafter Case used existing Terratrac parts but put their own name on the engine hood. Case renamed many of the former Terratrac mnodels. For a list of models and serial # by year of Terratrac models see the "Unofficial Terratrac Page" run by Ben Swart from Michigan:
Link
Other than that, guessing from the numbers you provided, Terratrac had both a G30 and 356 models and if it was the first year or so of the transition there is a chance Case used the Terratrac model identification...just a guess on my part though.
Further identification of the engine would be helpful. It is an 'L'head (flathead) or OHV? If a flathead it may be a Continental engine and there would be a stamping on the head. The G30 used an F-140 Continental engine. Larger models such as the GT34, 400 and 500 used the F162 or F162A engine I believe. These are all 4 cyl. L-head engines for which parts are available from Wis-Con Total Power in Memphis TN. which owns both Wisconsin and Continental engine names. Case can still supply some parts and there are a few places on the net that have some mechanicals but almost no sheet metal is available. I have a Terratrac G500 which uses the F162 4 cyl L-head gas engine. It is a good crawler with an angle/tilt blade of unknown origin. Trying to find out what I had traded a tired cuddy cabin boat for is what brought me to my current very limited knowledge about Terratrac and early Case transitional crawlers.
Good Luck acquiring the little dozer
