WANTED: SLEEVE PULLER
Dave S
01-19-2004 09:24:03
Looking to buy a quality sleeve puller. Anybody tell me where I can get one? thanks, Dave S
Juan Rodriguez
02-27-2004 13:26:37
 Re: WANTED: SLEEVE PULLER in reply to Dave S, 01-19-2004 09:24:03
I am selling a good sleeve puller, that can be use on all kind of tractors or heavy equipment. if anyone is interested, send me a e-mail and i will send you a picture of it, and how much I'm asking.
Bob
01-20-2004 13:29:47
I need to pull a sleeve on a 48 D soon. If anyone would like to share the diagram and instructions I would appreciate it. I have to get a second heat into the shop, made the mistake of going with off peak and it is always off around here. Was just out there and it is 38 in there. [email protected] Thanks, Bob
Dave S
01-21-2004 00:55:32
 Re: Re: WANTED: SLEEVE PULLER in reply to Bob, 01-20-2004 13:29:47
Bob, I just made a puller tonite at work. I'll see how it works and will let you know. Made really heavy duty. Dave S
C. Amick
01-19-2004 14:48:30
I have a photo of the one I bought that I can send you. If interested, send me your email address.
Walt
01-19-2004 11:28:36
Steve, if you have a welder,ox/acc. torch and a couple of hours you could make your own puller. If I did anybody could. I think the failure of most home made pullers is the central threded rod. That is something that you will probably have to buy. Mine is a 3/4" coarse thred. The bottom plate is 5/8" thick cut with a torch a little larger in diameter than the sleeve with the hole in the middle for the rod. The top works looks like a "C" with the two up rights about 6" high. The spred has to be of course more than the sleeve dia. the cross part which is welded to the uprights is a 2" by 2" square stock with the hole in the middle. The up rights are 2" by 1" bar stock. Simply tighten it up making sure everything is centered and tap on the bottom plate you made. Then tighten the top nut judiciously, go back and forth and it should rise above the block deck surface, then you have it on the run. Be careful not to go too far and ram your bottom plate into the sides of the lower block skirt. This will happen when the sleeve is about two inches above the block, depending how big you made the lower round plate. If you have a high speed internet connection I can send you detailes pictures of mine.
high speed internet
02-17-2004 14:45:57
 Re: Re: WANTED: SLEEVE PULLER in reply to Walt, 01-19-2004 11:28:36
high speed internet, 24 hour fitness, the hun, watches, internet bingo, virtual casino, online bingo, internet blackjack, facial skin care
Elliott from ILL
01-19-2004 17:51:43
Dave I did the same thing. Its not that hard to make. Better then some market ones. Elliott from ILL
Bruce Nelson
01-19-2004 10:34:28
I have one, e-mail me for details. Bruce
CRUSADER
01-20-2004 15:50:25
 Re: Re: WANTED: SLEEVE PULLER in reply to Bruce Nelson, 01-19-2004 10:34:28
Bruce,
Could you please send me a copy of the drawing or picture of your sleeve puller. I will (hopefully) be needing it to pull the sleeves out of a couple of tractors to do an overhaul on in the near future.
Thanks,
Jim
[email protected]
