CASE 830 Gas and Diesel Starter Swap
Lamont
01-18-2004 15:46:08
Does anyone know if a CASE 830 diesel starter will fit on an 830 Gas? I'm rebuilding a gas burner with high compression and am thinking the diesel starter would do a better job. Please help and thanks in advance.
JIM H
01-19-2004 17:10:19
 Re: CASE 830 Gas and Diesel Starter Swap in reply to Lamont, 01-18-2004 15:46:08
replaced original starter on 400 gas with delco starter from 930 diesel local starter shop found correct drive for it hope this helps JIM
Thad
01-18-2004 16:02:08
Flywheel ring gear is diffrent.
Lincoln
01-19-2004 08:24:03
 Re: Re: CASE 830 Gas and Diesel Starter Swap in reply to Thad, 01-18-2004 16:02:08
Can you use the gas starter drive and the diesel starter motor? Just a thought.
