HELP !! STILL NO POWER
chuckles
01-18-2004 12:22:55
My old girl is letting me down!! Timing done, Plugs done, Points/cond. done, carb. rebuilt,kicked in the A.. but still bogs down while trying to drive. Idles good,Revs up good. Will not drive. One thing not done maybe carb is set wrong from rebuilder, would anyone know for sure the right settings for the carb. Air , rich lean so forth. Would much appreciate help, hate to see the old girl down like this, plus snow to push. Chuckles !!!!
chuckles
01-20-2004 10:57:52
 Re: HELP !! STILL NO POWER in reply to chuckles, 01-18-2004 12:22:55
Well have tried everything possible timing,points condensor,carb, air, flushed out the fuel system,reset carb, tried different settings on the plugs and points, will idle perfect, rev up BUT will not pull a snail. Unfortunately it has got me and also a mech. at the tractor shop cannot figure it out has anyone any more suggestions or is this all. The old girl will be on the selling block tomorrow.Must not like it here in Ontario Canada.
Dave
01-20-2004 13:31:30
 Re: Re: HELP !! STILL NO POWER in reply to chuckles, 01-20-2004 10:57:52
Chuckles,
did you flush out the gas tank, remove the fitting for the fuel delivery, the fitting right out of the tank, clean everything out. Re-run a piece of fuel line as a temporary delivery line. Was the tractor running and all of a sudden it stopped?
chuckles
01-21-2004 14:14:48
 Re: Re: Re: HELP !! STILL NO POWER in reply to Dave, 01-20-2004 13:31:30
Yep ! Had the tank down to the rad shop for flushing last night got it back today, same thing.
But talked to an old farmer this afternoon who said he had a problem similar with another tractor and found sludge in his transmission,diff. put diesel fuel in it flushed it through it worked fine. SO I checked the trans case and low and behold what should I find sludge in the trans. case . Well will try this next. If this don't do it Ya'll will hear a sonic boom way down south and find pieces of a case tractor out to the west coast. Chuckles
C. Amick
01-19-2004 09:33:53
Carburetor float could be set too low. Does choking it help? Is the governor working? Start it and hold the brakes on and ease the clutch out a little with it in gear and see if the governor moves. Did you replace the condenser before or after this problem started? I have gotten bad condensers.
Dave
01-18-2004 18:19:49
chuckles,
We had the same problem on a 1949 SC. I rebuilt the carb and did the timing and cleand the plugs.
Still bogged under load.
When I removed the sediment bowl from the tank, there it was, the small screen into the sediment bowl was clogged enough to restrict the flow of fuel under load.
I cleaned the screen and was plowing like crazy after that.
sometimes the craziest problems are fixed by the simpelest fixes
Dave
todd hamilton
01-18-2004 13:37:31
It has got to be starving for gas. If you choke it a little (about 1/4 to 1/3) under load does it smooth out? If it does adjust the lean/rich about 1/2 turn out (to the rich) or until it acts like it is starting to choke and the back to lean just enought to smooth the engine. If this adjustment is over sensitive make sure you do not have a partial blockage in the fuel line or bowl.
Allan C
01-18-2004 13:55:58
 Re: Re: HELP !! STILL NO POWER in reply to todd hamilton, 01-18-2004 13:37:31
Have you checked the aircleaner. Try running it with the airhose off for a bit. Or a plugged muffler.
