Category I and II hitches
Jeff
01-18-2004 08:23:41
What is the best way to change from a category I to a category II hitch. I have thought of drilling the hole in the balls out, of cutting off the small balls and welding bigger balls on. This sounds bad - let me rephrase. Welding a cat. II onto a cat I. Or I have thought of ordering new arms from the dealer.
F-I-T
01-18-2004 08:42:44
 Re: Category I and II hitches in reply to Jeff, 01-18-2004 08:23:41
Jeff:
Years ago, I installed some of those spee-balls that had two sets of holes in them, both Cat 1 & 2. So, you could just select between Cat 1 & 2 for the implement you had attached at the time. A bit of a hassle to get the old spee ball out, but once you were through with that, the new ones welded right in. This way, you won't need bushings in case you ever need to go back to a Cat 1 implement.
Frank
Jeff
01-19-2004 18:36:57
 Re: Re: Category I and II hitches in reply to F-I-T, 01-18-2004 08:42:44
Thanks Frank, I'll try that.
