case c axle locknut
robert
01-17-2004 17:44:41
Dkase,Casenut, Thanks for replies. After removing hub without breaking it, The ''locknut'' was screwed out about 6 turns. Do i just tighten it up against the end of the axle housing? How do i adjust axle end play or dont worry about it?
Casenut
01-18-2004 06:10:57
 Re: case c axle locknut in reply to robert, 01-17-2004 17:44:41
The nut needs to be adjusted with the wheel on and tight. Make sure adjusting nut is all the way in before tightening. There should be a bolt going through the wheel which goes into the notches in the adjusting wheel that needs to be removed or backed out. With the wheel jacked up turn the adjusting nut There is 2 large holes in the wheel you can place a pry bar through to turn adjusting nut. Turn the adjuster to the left until all the freeplay is taken up and reinstall locking bolt back into wheel.
