Hydraulics
B.Reves
01-17-2004 16:45:15
Need to know how to get ALL hydraulic oil out of system. We still have dirty oil where you check the level. Already drained the 2 drain plugs on the bottom of the tractor.
Case 830 Comfort King(Caso-O-Matic)
Thanks
B.Reves
01-18-2004 07:14:29
 Re: Hydraulics in reply to B.Reves, 01-17-2004 16:45:15
I would like to know how to completely drain the hydraulic oil from the rear box on the tractor, where you fill the tractor with hydraulic oil.
Thanks
Lincoln
01-17-2004 17:48:08
Once you have the drain plugs out and the oil has drained out take a flash light and look up in the holes. In the back one you will see a plug that takes an allen wrench to remove. This will drain the dual range housing. In the front one you will have to turn the motor over untill you can find the plug in the torque converter. Remove this plug and it will drain the converter.
