Tractor belt pulley size vs. implement speed
Mike Schotte
01-15-2004 18:58:41
Could somebody educate me about belt driven implements, please: (as I have no experience with these.)
Does the belt pulley size on a tractor relate to it's governed engine speed to make some industry "standard" feet-per-second of belt, or is the size based on delivery so many foot pounds of torque... or what?
Would you have to do some careful matching to use a tractor that is in the right horsepower range for your belt driven implement, or could anything be driven properly by the biggest tractors without any problem?
The reason this comes up is because Dr. Cy Kosis and I were just talking about his hay baler- and he mentioned that the belt pulley speed on his '29 L was quite fast, even at idle. He also mentioned that the belt pulley speed on the McCormick-Deering 22-36 was quite slow...
Thanks in advance for any help.
-Schotte
Paul Janke
01-17-2004 14:29:00
 Re: Tractor belt pulley size vs. implement speed in reply to Mike Schotte, 01-15-2004 18:58:41
Standard belt speed is supposed to be 3100 feet per minute. Higher horsepower tractors usually have larger diameter pulleys. That would give a longer contact area for the belt on the pulley so it would be less likely to slip.
Don E
01-17-2004 02:12:05
Has anyone here seen two tractors driving one machine? belt over belt. It takes some throttle coordination but it works when the only tractor that's big enough breaks down. Quite a sight.
dctom
01-16-2004 03:34:09
MIKE; BACK IN THE OLD DAYS I REMEMBER WHEN A NEW BELT DRIVEN MACHINE WAS BOUGHT THE PULLY ON THE MACHINE WAS SIZED TO WHAT TRACTOR WAS GOING TO RUN IT , WE ALWAYS HAD CC AND DC TRACTORS AND I KNOW THE DEALER SIZED THE PULLLY ON OUR NEW MCORMIC SILO FILLER TO OUR TRACTOR, DCTOM
todd hamilton
01-16-2004 03:30:43
Hi all - checked the dictionary and thresh or thrash are both correct verbage. SC service manual on page 4 says: Belt pulley diameter 9 and 1/4 inches, face 6 and 3/8 inches, no load speed 1180 rpm, full load speed 1078 rpm, belt speed 2600 ft per minute, ratio engine speed to belt pulley speed 1.438 to 1. So roughly full throttle on SC at 1550 rpm (full load speed) would turn the belt at 1077 rpm. I suspect 1000 rpm was standard belt speed. Thus endeth the lesson.:^)
Klyde
01-15-2004 21:18:00
Seems like they standardized it at 1100 ft/min. i got an old book that lists that in my tool box. but you hafta wait till friday. Its -10F and the wind is blowin 40 mph right now.. cya
tinman
01-15-2004 19:55:15
The only thing I can add is that my dad used to say the implement should be up to speed at 1/2 throttle.
John H-WI
01-15-2004 19:30:18
Mike, the only implements we used belts on back in the farming days were the silo filler and threshing machine. The SC could handle the silo filler but not the thresh machine. The pulley on the tractor was always smaller than the implement. Standard size on the Case and the newer Farmalls and John Deeres. We were having trouble one Fall and the dealer sent out an F-20. They had a big pulley and we couldn't turn the filler fast enough to blow the silage up 45 feet. Pulleys same diameter. Had to put a small pulley on the filler to make it work. Not scientific but thats most likely the problem with the old McCormick-Deering.
todd hamilton
01-15-2004 19:25:32
Hey Mike, I don't know any specs on belt pulleys. However, here in the midwest, thrashing wheat is a common exhibit at tractor shows. There is usually a team leader that has the engineer (tractor operator) carefully adjust belt tension with the tractor position. Tension seems to be critical. Then they adjust to the rpm needed for the implement. The process usually takes several minutes. The load seems tremendous as the tractor (whether steam or gas internal combustion) really "talks" when they load up the separator with wheat. Last summer I watched two thrashers side by side. One was driven by a steam tractor (Case I think) and one was driven by an LA Case. Quite a site.
John H-WI
01-15-2004 19:33:08
 Re: Re: Tractor belt pulley size vs. implement spe in reply to todd hamilton, 01-15-2004 19:25:32
Todd, in our old threshing circle we had had M's and DC's on the thresher. Handled them fine. Takes snort when the belt is that long.
