Piston Rings
Older Abe
01-15-2004 17:42:20
Does anyone know if aftermarket piston rings are available for a Case 500 with a 377 cu. in. diesel engine 4" bore?
Any help would be appreciated.
Thanks in advance.
John Saeli
01-16-2004 05:29:35
 Re: Piston Rings in reply to Older Abe, 01-15-2004 17:42:20
Hey Abe: Those rings should be readily available. I can help you if you can't find them locally.
caseman-d
01-15-2004 18:25:58
I do beleive the rings are still available from case. I had checked on them a couple years ago and I do beleive they are available. I suppose I should check tomorrow as I will be needing some also.
caseman-d
