case c hubs
robert
01-15-2004 16:44:16
junk rim previous owner tried removing hub no luck I am going to use a puller and heat the cast center. after inspection behind hub is a gear that spins freely that can be turned from the outside of the hub through two slots. what are these sprockets for? any tips on hub removeal?
Casenut
01-16-2004 16:27:50
 Re: case c hubs in reply to robert, 01-15-2004 16:44:16
I have taken several wheels off C and L Cases. I use a logging chain, wrap it around the spokes on each side and place a bottle jack between the axle and the chain. It should come off very easily. (the shaft and hub are tappered)
DKase
01-15-2004 17:06:00
That is the lock nut to set the rear axel bearings. When I took the rear wheels of my D, I pushed them off with 2 hyd. jacks, 1 in front of the axel, and 1 behind the axel. LOL
