S C case tractor I.D.
Megan
01-15-2004 15:08:27
A friend of mine recently acquired a SC Case tractor with the serial number SC0840543. Can anybody tell us what year or any other info this number will tell? Also, it is leaking oil out around the starter where it bolts up at is there a fix for this and what would it be? Is it a wet clutch? It has a tricycle front end on it. Thanks in advance for any help
Megan
dctom
01-16-2004 17:14:39
 Re: S C case tractor I.D. in reply to Megan, 01-15-2004 15:08:27
ON THE LATER ONES LIKE THIS 54 THERE IS A O RING ON STARTER TO SEAL IT
Fredct
01-16-2004 16:08:35
Megan, yes the SC was/is a wet clutch - at least the earlier ones like mine which is a '44. I have been told that a gasket is required between the starter and the block but, I have not purchased one yet - anyone know where this gasket can be found? CaseIH? Aftermarket? FSB
need a 54
01-16-2004 14:31:24
Megan,
Where are you at and do you want to sell that 54
Megan
01-16-2004 20:14:55
 Re: Re: S C case tractor I.D. in reply to need a 54, 01-16-2004 14:31:24
You all are correct about the number it was 80 instead of 08. My friend wrote it down write but told me wrong. The tractor belongs to a friend of mine. I will ask him if he wants to sell it. He is going to make a gasket for the starter so it will quit dripping oil. Thanks for the help
Megan
Rob in Virginia
01-16-2004 09:12:56
There is supposed to be a gasket where the starter bolts up. Yours is probably dry rotted or missing. Don't know if anyone sells them or not. You could probably make one??
dctom
01-16-2004 05:56:42
MEGAN, 8040543 SC WAS BUILT MAY 5 1954 AND SHIPPED TOJ I CASE COMPANY ST. LOUIS MO. MARCH 20 1956 SO IT IS A 1954 MODLE WITH A FOOT CLUTCH DCTOM
Al
01-15-2004 18:01:03
I think your serial no. should read 8040543.If so tractor is a 1954.
dctom
01-15-2004 15:26:49
MEGAN, HOPE SHOULD IT BE SC 8040543?? I WILL LOOK IT UP TOMORROW AND POST IT HERE FOR YOU, HAVE COMPANY TONIGHT DCTOM
John Miller
01-23-2004 14:57:22
 Re: Re: S C case tractor I.D. in reply to dctom, 01-15-2004 15:26:49
megan its a 1954 and a case dealer should have the gaset for the starter make sure that it put on right and the adjusting screw is turn down and wiggle starter when you thighten it
