VAC thermostat/water pump
vacnut
01-14-2004 19:46:00
Where can you find a new thermostat for the upper hose of a VAC. Also, where is a good place and price for a new water pump.
Ugly Chicken
01-15-2004 18:45:23
 Re: VAC thermostat/water pump in reply to vacnut, 01-14-2004 19:46:00
As Far as the thermostat goes CASE has original bellows type for about $20.00, or you can do what I did, I had a 54mm GM thermostat and I ground the flange on the bench grinder, (carfull it will get hot), till it was the same diameter as the thermostat housing, about $3.00 for a GM thermostat(small block Chevy).
Barry F
01-15-2004 07:39:33
I just did a lot of work on my VAC and found something interesting. It didn�t have a thermostat before, but I put one in. And because I had done a bunch of work I got a batch of cooling system cleaner stuff and ran it following the directions. The thing warmed up to temp, and worked flawlessly. This was with just water and the cleaning stuff. Then I drained and rinsed, and put in antifreeze. And it immediately went to spells of serious overheating. This kind of annoyed me. I drained the nice antifreeze/water out, and put in straight water again. It worked fine. I looked at it again, and thought about the way that the thermostat is out on top of that elbow, right where the fan blows on it. I went and got some ugly pipe insulation, wrapped the elbow, and now it works. I think it just wanted special attention. This took longer and was far more frustrating than this summary makes it seem.
F-I-T
01-15-2004 07:02:24
VACnut:
I installed a new water pump on my VAC. I bought it from V*A*L*U-B*I*L*T and it was $75.00, no exchange. On the thermostat, I went to the car parts store with my upper hose, and I found one that would slip right in for $8.00. Actually, it is the same size that my JD 855 uses. Just caliper the skirt for size, then match up the temp you want.
Frank-in-LA, until the weekend when I'm once again, I will become.....
"FRANK-IN-TALLAHASSEE"!!!!!
