SC Case Horsepower
Glenn F.
01-14-2004 18:19:46
I forget the year, but in the later years of SC production cylinder bore was increased from 3 and 1/2" to 3 and 5/8". The RPM's were also increased from 1550 to 1600. Was the increase in HP noticable?
C. Amick
01-15-2004 10:01:47
 Re: SC Case Horsepower in reply to Glenn F., 01-14-2004 18:19:46
There were also 3-11/16 aluminum button topped after market pistons available. The increased bore coupled with an increase in RPM's due to the aluminum pistons versus cast iron ones could probably boost the horsepower around 10 HP.
Larry S
01-15-2004 07:00:03
I have a 53 SC and pull both a 3/14 3 point BER series plow and a trailer 3/14, my earlier SC does a nice job with a 2/16. Here in central Minnesota I have a maryland loam type soil, not real clay but not real light. No liquid but at least 2 weights per wheel.
Wide Open
01-15-2004 15:15:16
 Re: Re: SC Case Horsepower in reply to Larry S, 01-15-2004 07:00:03
Larry, where are you located in central Minnesota? Just wonderin where other fellow tractor lovers are from. I live near Sauk Centre.
Eric Rylander
01-15-2004 17:12:06
 Re: Re: Re: SC Case Horsepower in reply to Wide Open, 01-15-2004 15:15:16
My tractor is in my dad's shed north of Grey Eagle, I live in Savannah, GA
Eric
vacnut
01-14-2004 20:03:26
The original Nebraska test of 1941 rated it a max of 19.4 drawbar hp (pretty close to VAC's would you say?!), after the engine improvements of 1952 you speak of, a new test in 1953 showed 28 horsepower at the drawbar. My books do not say if the older test was gasoline or distillate but the later test was on gasoline.
