Implements for a Case VAC, how much work.......
Dave
01-13-2004 16:24:16
Hello all,
I just want to know how much work a Case VAC could do. ie pull a plow, how big, will it pull a brush hog. I was under the impression that a VAC could also use a bucket. But I see that the tires are really small.
How would this tractor compare to say a Case SC.
Thanks I am almost in the process of buying one.
I don't want to lead the guy on if I am not going to buy.
Thanks all
Dave
C. Amick
01-14-2004 07:30:30
 Re: Implements for a Case VAC, how much work..... in reply to Dave, 01-13-2004 16:24:16
My dad's VAC will barely pull 2-12's in 1st. gear here in WV. It does pretty well with the 5 ft. brush hog. We keep a 6ft. rear sickle bar mower on the VAC most of the time. The SC will pull 2-14's in 2nd. gear and easily run a 5 ft. brush hog.
vacnut
01-14-2004 19:34:15
 Re: Re: Implements for a Case VAC, how much work. in reply to C. Amick, 01-14-2004 07:30:30
Have VAC with mounted 2-14's and pulls hard in 1st through old hay field (alfalfa, other grasses). Can plow in 2nd through old black soil garden, however it can hardly move through gumbo even with wheel weights, it spins. Are either of these Eagle Hitch tractors, or does SC have a foot clutch and live pto and/or hydraulics ?
C. Amick
01-15-2004 06:07:02
 Re: Re: Re: Implements for a Case VAC, how much w in reply to vacnut, 01-14-2004 19:34:15
Neither the VAC or the SC have eagle hitches. The VAC has the belt pulley hydraulic pump. The plows I spoke of are trail type plows mounted on wheels. Actually I have 4 - SC's that are running, all have hand clutches. Some are equipped with a hydraulic lifting bail. The hand clutch seems to perform much better than the foot clutch on the SC's.
Ross
01-15-2004 18:25:42
 Re: Re: Re: Re: Implements for a Case VAC, how mu in reply to C. Amick, 01-15-2004 06:07:02
VAC and SC do have eagle hitches do a search on FIT's VAC (The one that's being restored really nicely). Later VA had a pump that ran off the engine giving them live hydraulics. Later SC with the foot clutch had the eagle hitch as well.
Ross
Glenn F.
01-13-2004 18:04:59
2-12's was too much for our VAC here in NE Wisconsin.
dctom
01-13-2004 17:18:07
DAVE SC IS BIGGER THAN A VAC COMPARABLE OT AN H FARMALL VAC COMPARES TO B FARMALL VAC WILL PULL 2 14'S AND A 5 FT BUSHHOG DCTOM
