830 D Oil in Water
Bill
01-12-2004 17:28:35
I have an 830D standard getting oil in the water. What could be the problem? Is it worth fixing or should i just part it out?
Rollin
01-18-2004 10:40:11
 Re: 830 D Oil in Water in reply to Bill, 01-12-2004 17:28:35
Just went through this with a 730 D ( same heads as your 830) Both heads were cracked in the combustion area. These heads a famous crackers, everything from low coolent level to either can do it. I found some good cores for $50 each, spent $500 on them at my local Diesel shop, but now have all new valves & guides. Welding or stiching cracked heads is iffy at best ( good luck finding someone who will even try) BTW the tractor ran great even with the cracks. It's easy to pull the heads, email me if u need more info Rollin
Jeff From WI
01-13-2004 06:33:32
Hey Bill, It may be leaking by the fuel pump? Where are you from Bill?
John Saeli
01-12-2004 18:15:48
Hey bill: Don't give up so easy!! How's the rest of the tractor? Water in the oil is a little easier, we'd probably say o-rings on the bottom of the sleeves. If it's C-O-M, I've heard of converter oil contaminating the coolant through a bad radiator. If it's engine oil, it's got to be the head or head gasket. Hope this helps.
Bill
01-12-2004 19:45:43
 Re: Re: 830 D Oil in Water in reply to John Saeli, 01-12-2004 18:15:48
It is engine oil in the radiator. It has the dual range 8 speed trans. Fair shape, starts hard though. Clutch seemed a little on the weak side to me too.
John Saeli
01-13-2004 05:28:44
 Re: Re: Re: 830 D Oil in Water in reply to Bill, 01-12-2004 19:45:43
Hey Bill: Hand clutch or foot clutch? Have you been using ether? If so, expect the worst.
