URGENT David Brown 990 Imp. PTO housing removal
Justin
01-12-2004 00:20:28
How do i remove the PTO housing in order to remove hydraulic pump. There seem to be 13 bolts and a dowel? of some description that have to be removed.
How is this dowel removed and what is the approx weight of the housing?. Also is the housing sitting on a spline and if so how far back is nessesary to clear the spline when removing.
Searched through the board with no avil.
Thanks in advance
Justin.
Elmer
01-12-2004 04:18:14
 Re: URGENT David Brown 990 Imp. PTO housing remova in reply to Justin, 01-12-2004 00:20:28
Remove all the bolts and then what i usually do is pry between the rockshaft of the 3 point hitch and the plug on the top of the pto box, holding onto the pto shaft and lifting up and down. You can even drive a screw driver between the axle housing and the pto box at the dowel. The box weighs abot 70 pounds. I usually lift it off by hand. When going back on the lube line from the pump goes into the rear of the box to lube the gears, make sure it goes in alright. When coming off it clears everything when drawn back about 6 to 8 inches.
