Question for DC pullers
More PWR
01-11-2004 22:31:44
I've heard you can use Allis WD (or WD-45?) pistons that are 4 1/8" bore in a DC. First, is there anybody out there that has done this? Second, does the wrist pin location line up or do you use Allis rods or modify the originals? Of course, the sleeve walls get REAL thin!! Any problems with this?
mike's 600
01-12-2004 16:47:11
 Re: Question for DC pullers in reply to More PWR, 01-11-2004 22:31:44
Bore the block and use LA pistons and sleeves 4 5/8.
DC DENNIS
01-12-2004 17:58:23
 Re: Re: Question for DC pullers in reply to mike's 600, 01-12-2004 16:47:11
GOT 4.125 AC PISTONS IN MY 1937 CC FOR 4 YEARS NOW AND HAVE NO PROBLEMS,USE YOUR DC WRIST PINS, CUT THEM TO FIT INSIDE OF THE AC PISTONS WITH A LITTLE SIDE CLEARANCE, THEN BORE THEM OUT TO FIT OVER YOUR AC PINS, THEN CUT THEM LENGTHWISE SO YOUR CASE ROD WILL CLAMP DOWN ON THEM.TRUST ME IT WILL WORK. E-MAIL ME IF YOU NEED MORE IMF.I USE THIS TRACTOR TO PULL A 3-14 OLIVER TRAILER PLOW CAN PULL IN 3 RD GEAR SANDY SOIL MOVES ALONG REAL GOOD. DC DENNIS
bill
01-12-2004 18:11:56
 Re: Re: Re: Question for DC pullers in reply to DC DENNIS, 01-12-2004 17:58:23
wd or wd45 pistons ????? ?
DCDENNIS
01-13-2004 18:37:47
 Re: Re: Re: Re: Question for DC pullers in reply to bill, 01-12-2004 18:11:56
My old central tractor book shows 4.125 in a W,WC,WD,WD45, GAS got mine off the shelf at local salvage yard $70 for 4, book also shows 170,175 ac gas be sure you check compression hight. LOL DCDENNIS
