case sc transmission noise
Walter
01-11-2004 18:50:11
I have a lot of growling and grumbling going on in my tranny . Sounds worst is 2nd and reverse. Esp reverse. Any idea where to look first. Should I keep running it or tear down now? Pulls good, no real loud poping or snapping sounds, just sounds like a bad bearing or something. Makes the noise also in neautral when the clutch is engaged but not nearly as bad. When it gets in a pull it seems to get better.
todd hamilton
01-11-2004 19:11:03
 Re: case sc transmission noise in reply to Walter, 01-11-2004 18:50:11
You might want to try draining the tranny, flush it with kerosene, then replace the oil with 85W-140. Holds approximately 10 gallons. The SC owner's manual says to run light oil in cold weather and heavy in hot weather. I had some noise in mine and did this. It really helped. I had a loud bearing squeal on the main shaft (squeal affected by engine RPM) in real cold weather. The oil in mine was probably 36 years old or more - real cruddy.
walter
01-11-2004 19:45:48
 Re: Re: case sc transmission noise in reply to todd hamilton, 01-11-2004 19:11:03
I'll try it it, looks pretty dark, but I didn't want to change the oil if i needed a tear down.
John Saeli
01-12-2004 04:26:16
 Re: Re: Re: case sc transmission noise in reply to walter, 01-11-2004 19:45:48
Hey Walter: You can try what Todd says, but if your luck is like mine, you got problems. I suspect a bad brg. & bushing on the input shaft causing the ring & pinion to be out of mesh.
walter
01-12-2004 05:48:34
 Re: Re: Re: Re: case sc transmission noise in reply to John Saeli, 01-12-2004 04:26:16
I know a fair amount about engines but nothing about transmissions. So you are talking greek to me here. If you could, explain to me what and where to look . Is there any way to diagnose the problem before tear down? I assume I will need to split the tractor. How will I know when I've found the problem? I agree with you on the mesh thing thats what it sounds like to me ,, slack or mesh or backlash whatever that is. Thanks!
John Saeli
01-12-2004 18:27:38
 Re: Re: Re: Re: Re: case sc transmission noise in reply to walter, 01-12-2004 05:48:34
Hey Walter: On the chain drives, the input or clutch shaft has the pinion gear on it. It meshes with the ring gear. The belt pulley is on the shaft supporting the ring gear. A quick way to tell is to roll the belt pulley back & forth and see how much backlash you have there. Leaking oil would be a clue to something up. The biggest clue you gave was the complaint of noise in neutral with the clutch engaged. Yes, the tractor would have to be split. Tell us what you find before grabbing the wrenches.
walter
01-13-2004 18:45:44
 Re: Re: Re: Re: Re: Re: case sc transmission noise in reply to John Saeli, 01-12-2004 18:27:38
Oil is leaking from beneath the belt pulley.
No play in the belt pulley shaft up and down or right to left. When I roll it back and forth its hard to tell about backlash but I hear the noise I'm referring to. Under power the belt puley seems to jump or look like it out of round but I can't see anything to justify this.
