Zenith updraft carb
rbradk
01-11-2004 14:16:01
My early 50's VAC needs a new carb. The tag # is 12522. I was giong to order a new one from this site but I am not sure of the TSX #. Does anyone know if this is a TSX597 or a TSX663. Any help would be appreciated....
Thanks, Brad
Duane Larson
01-12-2004 15:53:59
 Re: Zenith updraft carb in reply to rbradk, 01-11-2004 14:16:01
Brad,
Case mostly used Marvel Schebler TSX series carburetors on their V and VA series, and some Zenith series 161 also. The MS-TSX-114 was used on VA series gas burners, while the TSX-253 was used on all-fuel engines. The 114 was superceded by the TSX-597, while the 253 was superceded by the TSX-663.
The VA series also used a Zenith 11106 carb (1950-52) and a 11506 (1952-53), (both of which were to be replaced by the TSX-597 if a replacement was needed, according to the Case VA parts manual). The replacement carb for the 11106 and 11506 Zenith carbs was the 12522 Zenith. So, your tractor has a Zenith replacement 12522 carb. I have seen few VA series with Zenith carbs, but most have MS.
FWIW, MS was bought out by Zenith about 20-30 years ago, and the TSX-114 and 253 were replaced by a Zenith 14544, and the TSX-597 and 663 were replaced by a Zenith 12566.
The Zenith 12522 may still be available, I can check if you would like. But, the point is you are looking for a Zenith carb, not a Marvel Schebler TSX.
Zenith carbs can be rebuilt - most all parts are still available.
Hope this helps sort this out - more than you ever wanted to know, probably...
Joe (Wa)
01-11-2004 21:28:13
TSX-114 is the normal Marvel carb for 50's VAC. TSX-597 is listed in the parts catalog as replacement for TSX-114 but comparing the p/n's the power jet is different. Something to check out I guess. Joe
old
01-11-2004 16:26:47
The catalog I have says its a TSX114, the 2 numbers you lists are for VA Cases
