Swap SC Rear End
Walter with a V
01-11-2004 05:53:42
Does anyone know if it is possible to replace a 1945 SC rear end with a 1951 rear which has live hydraulics and a eagle hitch?
I have an overhauled 1945 with a bad rear end.
Your help would be appreciated.
Dave
01-11-2004 07:26:24
 Re: Swap SC Rear End in reply to Walter with a V, 01-11-2004 05:53:42
Walter,
I believe that the swap will work, BUT I think you need to change the flywheel to a smaller one, from a like year rear end.
Dave
Larry S
01-14-2004 07:30:45
 Re: Re: Swap SC Rear End in reply to Dave, 01-11-2004 07:26:24
I've made that swap, It does work but you have to swap the flywheel/clutch also, using the one that comes with the rear end
walter with a v
01-16-2004 14:32:14
 Re: Re: Re: Swap SC Rear End in reply to Larry S, 01-14-2004 07:30:45
Thanks for getting back to me. I may have more questions as I get closer to making the swap. If that is alright with you.
Walter with a v
