Help with VAC
Larry
06-17-1999 20:14:23
Just learning Case tractors.Does all VAC's have the big belt pulley or just some of them. Is there a lever to shut it off or does it always run. Thanks for some info.
toolbox
06-17-1999 20:38:12
 Re: Help with VAC in reply to Larry, 06-17-1999 20:14:23
There's a bolt and lock nut on top of the pulley housing. To disengage the pulley so it won't revolve, loosen the lock nut and the bolt. Then pull the pulley outward. This disengages the bevel gear. Re-tighten the bolt and lock nut.
Larry
06-18-1999 15:39:53
 Re: Re: Help with VAC in reply to toolbox, 06-17-1999 20:38:12
Thanks Toolbox
For my other question does all vac's have this pulley?
Craig Logsdon
06-18-1999 22:48:27
 Re: Re: Re: Help with VAC in reply to Larry, 06-18-1999 15:39:53
A belt pulley was an option for a VA series. You could take it off ( 4 bolts) and pull it out and put a flat plate over the hole and bolt the plate to the torque tube. that is the way the ones w/o belt pulley options were shipped
Craig Logsdon
06-18-1999 22:47:40
