VAC add-on 3 pt hitch
Pete
01-10-2004 11:28:50
I was woundering if any of you have any lititure on a add-on 3 point for an early VAC with high pressure hyd. I have a 46 with this option but cant find any liture on it. any photo copys or other other info would be appreciated.
Pete
mj
01-12-2004 18:49:12
 Re: VAC add-on 3 pt hitch in reply to Pete, 01-10-2004 11:28:50
third party image
Like this?
Pete
01-13-2004 18:16:34
 Re: Re: VAC add-on 3 pt hitch in reply to mj, 01-12-2004 18:49:12
Yes, that's the hitch I have. Would it be possible to email a printable copy, or photocopy and send it to me? I would appreciate it. Thanks, Pete
mj
01-13-2004 19:11:04
 Re: Re: Re: VAC add-on 3 pt hitch in reply to Pete, 01-13-2004 18:16:34
Click on the link 'Image Event' and then scroll down to the photo I showed here, click on it and you will see an enlarged view, click on 'Original' at the bottom of screen and then print the original. You can print the entire catalog this way...Roger?
mike's600
01-11-2004 06:09:00
Let me know what you fine out.I have two Vacs with 3pt non-eagle hitches.I would ilke to know where they were produced.
John S
01-11-2004 07:45:09
 Re: Re: VAC add-on 3 pt hitch in reply to mike's600, 01-11-2004 06:09:00
The hign preasure three point and the eagle hitch are two different birds. The eagle hitch is a low preasure system were as the high preasure system is a very detailed series of parts. I have picture of the original add on system but if you look up VAC high preasure lift in the descusion there are pictures it there too.
mj
01-14-2004 16:57:35
 Re: Re: Re: VAC add-on 3 pt hitch in reply to John S, 01-11-2004 07:45:09
John- I've been trying to determine a name to differentiate the hi-pressure system 3-point hitch from the later low-pressure 'Eagle' hitch...Case DID IT in the '40s! The catalog page shown here simply calls it the 'Eagle Hitch..... .CONVERSION TYPE' for the hi-pressure system so it's clear that Case considered this an 'Eagle Hitch' even though the later hitch was so different. By the way, have you seen a picture of the late Eagle hitch rockshaft housing mounted to the early hi-pressure rear casting? I've got one somewhere and will try to post it here soon.....mj
