Case diesel 830 Case-O-Matic
Robert
01-09-2004 01:22:01
What is the difference between the regular Case 830 and the 830 Case-O-Matic. I have driven one of each and they were both 1962 models I think. I was only 12 when I drove the Case-O-Matic so I don't remember much about it except the clutch pedal was like an excellerator pedal. Both are high crop models used on sugar cane farms in Louisiana and both are stilled used today only in limited roles.
Kirk-Tx
01-09-2004 06:10:06
 Re: Case diesel 830 Case-O-Matic in reply to Robert, 01-09-2004 01:22:01
The Case-O-Matic starts out like an automatic transmission of a car. At idle you may not move but add RPM's and tractor starts moving. When you engage the c-o-m lever, it is direct drive. We used it in row crop at the end of the field. You dropped into c-o-m and the tractor slowed down but PTO and rpm,s would stay fast. This allowed a shredder in heavy stalks to turn fast as the tractor slowed. You could idle down as you turned & enter the next rows. Go full throttle then pull it into direct drive. Works great.
