Case/David Brown 1490 3 pt arms/links
Craig M
01-08-2004 23:21:04
Tractor I just bought has a rear mount boom mower on it and is missing the 3 point arms and lift links. What models other than the 1490 will fit? Does anyone have the part numbers?
kyhayman
01-09-2004 18:57:24
 Re: Case/David Brown 1490 3 pt arms/links in reply to Craig M, 01-08-2004 23:21:04
Try Pleasent Hill Farm Supply in Pleasureville, KY, they have the 'mother lode' of Case/DB parts.
Regards,
David
JCmarleau
01-09-2004 06:49:51
Graig this is a little complex as for the lift link is it just the arm that hook to the equipment or the lift link from the top to the bottom and if so this is composed of many part number since they only sell this all in seperate part and not as an assembly. For instance here are the parts number for the third Bar. you will need one of K920798 Screw K920800 Turnbuckle and K964864 Screw and also two pin for each end part. K65690 and K919725. My e mail is [email protected]
