VAC Case starter
Todd in MO
01-08-2004 19:11:52
Sometimes when starting the ol Case, the starter will grind. I changed the starter and this other one does the same. This tractor has a 6 volt/12 volt conversion, but I am not sure if it is starting from 6 or 12. All of the teeth are on the flywheel and when it does engage, it starts fine. Love this site...Thanks for any ideas, Todd
mj
01-09-2004 15:10:33
 Re: VAC Case starter in reply to Todd in MO, 01-08-2004 19:11:52
Make sure that the Bendix mechanism is free and sparsely lubricated with a light oil. If it is binding up due to rust/grime or too heavy a grease or oil for winter temperatures the starter may not engage.
Pete
01-09-2004 01:30:05
hey Tod;
sounds like you have starter drive trouble, check to see if the bushings are worn and lettin the shaft move an not engauging the flywheel. also check the entire flywheel for a bad tooth. as far as a 12v conversion I assume you have a 12v battery and your starter must be turning on 12volt good luck
Jim
01-09-2004 19:03:17
 Re: Re: VAC Case starter in reply to Pete, 01-09-2004 01:30:05
I had same problem, and it turned out the big bendix spring was cracked
bill
01-10-2004 03:01:17
 Re: Re: Re: VAC Case starter in reply to Jim, 01-09-2004 19:03:17
Mine did the same thing until the spring fully broke. Then it just turned and never engaged at all.
