311 power steering
Terry
01-08-2004 10:39:15
I am sure this has been asked hundreds of times!
How dificult is it to put power steering on a 311.
I am getting to old to fight that steering wheel.
Are there any assemblies around, can one be made from non-case parts, maybe an aftermarket unit?
How about some ideas.
Thanks
Joe (Wa)
01-08-2004 17:08:42
 Re: 311 power steering in reply to Terry, 01-08-2004 10:39:15
Hi Terry,
I have a 311b with factory power steering and I think it has the same steering configuration as your 311 but am not positive.
The motor is a Char-Lynn torque generator mounted in the steering shaft just under the carburetor. P/n is 217-1015, hydraulic requirements are 3.5 gpm @ 1000 psi max. Normal working pressure on my 311b is 50-500 psi. They are available new from an Eaton distributor. Surplus Center (www.surpluscenter,com) also sells the motor for about $400.
The original hydraulic supply was provided by a Barnes spur gear pump mounted in the magneto opening on the engine and driven off the cam shaft gear. The reservoir is mounted on the pump. Pump is rated 4 gpm @ 1050 psi max. The pump is obsolete and doubtful that a working pump could be found aftermarket or in salvage yards. The options are either mounting a belt driven automotive type steering pump on the engine or using the tractor hydraulics with a priority valve.
I think if I were starting out from scratch, I would do a web search for after market steering sites. The link below does not mention Case tractors but perhaps they can provide some information.
Good luck, Joe
Terry
01-09-2004 08:37:23
 Re: Re: 311 power steering in reply to Joe (Wa), 01-08-2004 17:08:42
Thanks for the info.
I already called them, they didn't make anything for the case 311 or anyother 50's or 60's case.
case poor in pa
01-10-2004 15:09:59
 Re: Re: Re: 311 power steering in reply to Terry , 01-09-2004 08:37:23
didja try donL [email protected]
