SC Cast wheels??
G. L. Perry
01-07-2004 22:57:46
Got my wheels painted, one new tire so far. I have Dumb questions here on them. One side of wheel is dished heavier and other side fairly straight. SO, dish Does go to inside to hub, correct?? Reason I'm asking is the center where the bolts go in is odd for hex bolts. Are these just hex bolts? or should be tapered type like steel wheels? There is a couple of raised ridges around the center, one on each side of bolt holes. They got chewed up on mine some, cause the hex heads are big enough to rub on these ridges and push metal away. I'm wondering if these should maybe be allan head with round heads outside to fit down in the two ridges or if there is a trim ring of sorts to go over wheels to prevent bolts from rubbing there, OR, do I just need to get taper heads like the steel wheel has, only longer? What you guys have on yours?? I want to get these on soon, it's just bothering me that the bolts are gonna Peel off the paint around the wholes on these raised edges.
capt kirk
01-08-2004 06:47:31
 Re: SC Cast wheels?? in reply to G. L. Perry, 01-07-2004 22:57:46
dish to inside. straight bolts &lock washers
Klyde
01-08-2004 04:37:04
Hex heads and lock washers on all the cast wheels I've got.
