Need info on Case Crawler engine
Rich
01-07-2004 15:01:57
I just found out that Case used the JD382 Continential engine in some of it's crawlers. How much HP did this engine have? How many years were these used in the Cases and when was the last year that they were used? I'm a Massey- Harris man and would like to get my hands on an engine that had more power than the one's that were in the Massey 55's. Thanks for any info.
CASEPOWER
01-08-2004 09:57:16
 Re: Need info on Case Crawler engine in reply to Rich, 01-07-2004 15:01:57
JD 382 was 100 HP flywheel HP. Military used a JD 403 on a Davey Permavane Air compressor that will bolt right in. The difference between your massey 55 engine and a Case 1000 engine is there is a Balance shaft mounted below the crank on the Case because of the higher RPMs. The 403 also has a balance shaft.
Glenn/Mn
01-07-2004 18:17:18
was used in the Case 1000 Case 1010, look for other equipment that used these engines, the productions numbers are low as far as parts engines, 382 cu.in. 4 1/2 bore by 6" stroke 2000 RPM was said to put out 100HP I believe it is called a GD382 Continental Diesel
Rich
01-08-2004 12:07:35
 Re: Re: Need info on Case Crawler engine in reply to Glenn/Mn, 01-07-2004 18:17:18
Thanks for the info guys. Now the next step is finding one of these engines...
