whats the difference between an 811 and 830
David811B
01-07-2004 10:49:43
Anybody?
Roger
01-31-2004 07:35:51
 Re: whats the difference between an 811 and 830 in reply to David811B, 01-07-2004 10:49:43
Other than decals, dash, and some sheet metal differences:
800 = torque converter drive only. (700 is dry clutch)
830 = torque converter or dry clutch.
800 = (gasoline) 251 CID with 52 horsepower.
830 = (gasoline) 284 CID with 64 horsepower.
800 = (diesel) 267 CID with 52 horsepower.
830 = (diesel) 301 CID with 64 horsepower.
farmall
01-07-2004 16:11:26
A 811B is touque converter drive only. A 830 naturaly is newer, but you could get them with a standard clutch. The later 830's were comfort kings. The 830 had a bigger bore than the 811B.
The 711B and 811B were the same tractor except the torque converter drive in the 811B. Hope this answered your questions.
Jake
01-07-2004 16:07:49
I just posted a pic of each in the parts and pieces gallery. The brown one is from a 1958 811-b. The black one is from a 1964 741-c. This may or may not help you. We have a 1962 830 that has a totally different dash then either of these. I have never seen another like it. I may post a pic of it later. Jake
david811B
01-08-2004 06:55:31
 Re: Re: whats the difference between an 811 and 83 in reply to Jake, 01-07-2004 16:07:49
Is that brown dash for sale?? I don't see it attached to a tractor.-DB [email protected]
doh
01-07-2004 16:10:56
This was suppose to go below comparing the brown vs vlack cluster.
