Need an 800B expert!!
John Saeli
01-07-2004 04:48:25
Does the oil in the converter housing mingle with the oil in the tranny section? If they don't I want to use 85W-140 in the tranny. This tractor I'm working on has the thin oil in the tranny section.
caseman-d
01-07-2004 21:10:00
 Re: Need an 800B expert!! in reply to John Saeli, 01-07-2004 04:48:25
John,
I know your stuck on using 85-140 in the rear end but I wouldn't recomend it on the 800. The manual states use type A in the hydraulic which most people use hy-tran. The case o matic I would use Dextron automatic oil. I have been informed from past post that works better. If I remember right there is a seal from converter to the transmission and if that seal goes you could contaminate the convertor. I work for a Case dealer and they recommend hy-tran for everything now. My owner manual does state however to use 90w above 80 degrees and 80w at -20 for the 803 model. You will also be putting additional drag and slipping in cold temps on the clutches. Knew if I looked long enough I would find it. Capacities and oil recommendations, oil recommendations both summer and winter except during extreme temperatures when 5w oil is used in engine. Then use 5w MS-DG Oil in case-o-matic. In other words run the same as you do in the casematic. Mine I would run Dextron in caseomatis and hy-tran in transmision and rear end.
caseman-d
Klyde
01-07-2004 09:50:03
BUT is the hydraulic seperate?????
david811b
01-07-2004 10:40:38
 Re: Re: Need an 800B expert!! in reply to Klyde, 01-07-2004 09:50:03
yes
David811B
01-07-2004 06:57:57
They are seperate
