serial numbers
mike
01-06-2004 18:16:03
I need info where to find serial numbers on about a 1939 case maybe a d its mag is mounted backhalf of motor spark plugs are straight coming out of head 38 rear rubber fixed front axle. Thanks for all replys Shagman:)
John Saeli
01-06-2004 19:15:46
 Re: serial numbers in reply to mike, 01-06-2004 18:16:03
Hey Mike: Sounds like an old one. Serial # should be on a tag on the dash by the steering column. It is also stamped on the rear flange of the engine block, left side, behind air cleaner.
