I need a measurement
david811B
01-06-2004 13:24:05
I was fixing my LH Lift arm on my 800B It was frozen in the upper yoke so I had to cut it off bore it out and replace the threaded part. I can't remember how long it was. the part # is 010945AB I need to know how long the rod part is from the top of the lower yoke to the tip of the threaded part. No need to disassemble just get close so I can make mine the right size. Thanks in advance to anyone who has time to do this-David
tbair
01-06-2004 18:23:31
 Re: I need a measurement in reply to david811B, 01-06-2004 13:24:05
20 inches from top of bottom yoke to (as best I could tell} top of threads David. It is seized and I couldn't get it apart. How are you coming on your foot throttle? The wife says we can now email pictures if needed.
PLEASE send warm air this way 6 degrees -20 windchill.
david811b
01-07-2004 10:48:07
 Re: Re: I need a measurement in reply to tbair, 01-06-2004 18:23:31
A picture of your Dash would be wonderful if you got time-DB
David811B
01-07-2004 07:02:52
Thanks mine was siezed to so I fixed it had to replace the threaded part and bore the stuck part out of the yoke on a lathe. I am waiting on word from DONL about the foot throttle he says it's hard pulling parts in -20 weather!! He must be near you. Wouldn't mind seeing pics of your tractor. [email protected]
