Case 611B Value?
Dan
01-06-2004 08:30:45
Whats the value of a 58-59 Case 611 Tractor? My uncle may buy one. It is a Gas with case-o-matic NF. Tires not bad. Unsure if it turns over and don't know how long it has bees sitting, but is under a roof. It looks good on the outside except for some misssing covers. Tractor also has Complete 3 point hitch. Thanks for any info!
David J. Beiter
01-09-2004 13:18:18
 Re: Case 611B Value? in reply to Dan, 01-06-2004 08:30:45
My dad sold the one pictured in the photo section for $3750.00. Around here in central Ohio Case holds pretty good value..
Lincoln
01-06-2004 18:14:13
A dealer here in Iowa has a real nice one with a wide front, power steering, and four new tires. They are asking $3250. (I think its a little to high)
JRT
01-06-2004 17:05:56
I sold mine for $1800 but it had bad rear tires. Other than that it was in fairly good shape.
BLR
01-06-2004 11:24:54
If you can run the tractor, and determine all the systems, particularly the case-o-matic drive are functioning correctly $2000 may not be out of line. However, if you cannot run the tractor $500 may be too much, particularly if the case-o-matic drive has a problem.
