930 CK Dsl Power Cells
Paul f
01-05-2004 08:18:35
My brother is having to replace the Power cells in his 930. One was burned so badly it damaged the head, the others were burned to lesser extents. As this is turning into an expensive repair what should he do in the future to avoid a repeat? He is having the injectors tested to see if they have a good spray pattern...have also heard about the cells being sensitive to the additives (or lack therof) in diesel fuel. Any comments thoughts???
paul f
farmall
01-07-2004 09:23:27
 Re: 930 CK Dsl Power Cells in reply to Paul f, 01-05-2004 08:18:35
I worked for a Case dealer in the 70's and early 80's and worked on many powercell diesels. Your problem is the powercell is a 2 piece unit. They have to be lapped to each other for a perfect seal. If you install new one's without lapping them they will leak, causing them to erode the head. Old ones also need to be lapped, or any time you take them out. Hope this helps.
Paul F
01-07-2004 10:27:07
 Re: Re: 930 CK Dsl Power Cells in reply to farmall, 01-07-2004 09:23:27
Thank both of you for the hints.
John Saeli
01-05-2004 10:01:33
Hey Paul: Not sure what would cause them to burn other than poor pattern & heat. BUT!! I was told they are no longer available. Can't believe it. Keep us posted.
