Gas tank coating
Glenn
01-05-2004 07:38:16
Howdy Case Friends:
As long as I posting about the mag, I might as well ask about the gas tank as well. The tank on my DO is rusty. Tractor runs well, but after about an hour or maybe an hour and a half, the trash bowl starts to fill with rust. Have to shut the tractor off, clean the bowl, etc. It seems to me years ago, a person could buy a coating for gas tanks. I've looked at several auto parts stores but found nothing. The kids behind the counters have no idea what I'm talking about. Does anyone know if this stuff is still on the market? If so, where could I get it? Thanks again - Glenn
Errol CO
01-05-2004 21:51:25
 Re: Gas tank coating in reply to Glenn, 01-05-2004 07:38:16
The last time I coated a gas tank I got the tank sealer from a small plane parts supplier at one of the larger small plane landing strips. It was certified safe for coating the gas tanks on planes so I figured it was safe on the tank I had and when I got rid of it, it was still sealed after 6 years just as good as when I had originally put it in the tank.
The only problem is that I don't remember the brand but you could check with one of the small plane parts houses in your area. If what they sell is good for airplanes then I think that's a good sign that it should be great for our earth bound tractors.
old school
01-05-2004 17:07:23
I had the same problem with my SC man was it just about to drive me nuts. I clean the tank out with water let dry good then I used redkote, that was 5 years and no problems. I tried the stuff they sell at the motorcycle shop on my sons tractor and it cobwebed the in side so bad I had to get another tank
caseman-d
01-05-2004 11:46:46
Glen
I used some stuff called redkote, you rinse your tank good, get all the rust and fumes you can and when it's dry add the redkote and shake it around and drain the excess. On a nice summer day allow 24-48 hrs to dry. I bought mine at a Carquest auto parts store. Made by Damon Industries, Alliace NE, 1-800-362-9850
caseman-d
Bruce Nelson
01-05-2004 13:41:31
 Re: Re: Gas tank coating in reply to caseman-d, 01-05-2004 11:46:46
I have used Redkote with good results more than once. Bruce
Dr Cy Kosis
01-05-2004 11:44:29
I got great results from the Eastwood kit. Pricey but worth it.
Mark
01-05-2004 09:25:46
Used Eastwoods kit 4 years ago on my '73 Vette. worked great. Had no problems since. Their kit includes a complete service from cleaning on.
ff316
01-05-2004 08:14:25
Try the Eastwood company for MANY restoration products, I think POR 15 also makes a gas tank sealer but I am not sure.
Good luck. Fireman in KY
ff316 with link...
01-05-2004 08:20:46
 Re: Re: Gas tank coating in reply to ff316, 01-05-2004 08:14:25
Search www.eastwoodco.com for gas tank sealer, and here is a link for por 15's sealer.
Fireman in KY
Dave
01-05-2004 07:58:38
Hello,
There is a product called kream, you can get it through a motorcycle shop or any atv place. I have used it on a couple of occations.
Try this first, while you are lookin for parts for your mag, take the tank off and through a piece of small chain in it, slosch that around with a soapy water mixture and that should clean the inside of your tank. If there are no holes in the tank I would suggest NOT using a coating, they have been known to break down after while.
Good luck
Dave
G. L. Grumpy
01-05-2004 07:57:01
Auto or truck restoration parts places have that. Fellas on my Lists have used it, and some loved it, others hated it. This is usually an acid cleaner to remove loose stuff, then a white coating to seal it up tight. Some say if you don't get it fully covered, it peels off and clogs up again, real messy! Some motorcylcle places or mags have it listed for smaller tanks. Even J. C. Whitney has this stuff. Eastwood has it, but higher priced. You need to remove tank to be able to roll it around and such to cover it all. I have used "Iron Out", used for taking iron stains from clothes, and was pretty good, some say Muriatic Acid works, be careful with that, and others use cleaners and bolts or a chain to roll around inside and knock off the rust or bigger stuff physically. Then rinse and rinse with water sevral times. Check any truck or car magazine for ads for the acid and coating.
Rigidharley
01-05-2004 07:53:57
Hello Glenn,check with your local radiator repair shop,they may be able to direct you to a place that sells it,then again they may have a little leftover they'd give You.I know back when I pulled wrenches for Galloways radiator and truck repair we fixed and coated fuel tanks,this may not help but then again it just might prove to be the ticket. Jim
John H-WI
01-05-2004 07:58:43
 Re: Re: Gas tank coating in reply to Rigidharley, 01-05-2004 07:53:57
J.C. Whitney lists fuel tank liner kits for around $32. Never tried one so can't comment whether they work or not. www.jcw.com gas tank coatings
