VAC/VAC 14
Todd
01-05-2004 04:59:05
What is the difference between a VAC and a VAC-14?
John H-WI
01-05-2004 16:01:14
 Re: VAC/VAC 14 in reply to Todd, 01-05-2004 04:59:05
The VAC-14 was Case's first effort towards a utility tractor.
Rigidharley
01-05-2004 07:40:25
Hello Todd, I have a VAC-14 in my garage at this time,which I'm totally restoring for a freind. The vac-14 is more of a low pro as I call it tractor,The running boards,pedals,seat,and steering wheel all set down farther than a typical vac.A standard vac has running boards that mount at the top of the transmission case,a 14 is mounted at the bottom of the trans case which allows your feet to stradle the trans like like a massey,or ford.The seat,steering wheel and peddles are lower also.The sheetmetal is differnt also,along with a few other various things like the front axle,dash mount,and dash.My vac-13 shares the same front axle,sheetmetal,and dash, but all the pedals,running boards,seat,and steering wheel are mounted higher like a typical vac,or vai.The vac-14 is very easy to spot by the gear stick which is short and curles forward toward the dash, were a vac is longer and curles backward toward the seat.I myself like the vac better do to the fact I have a better few of things around me,just watch for low lying limbs (ouch). Hope this helped You. Jim
Todd
01-05-2004 13:10:58
 Re: Re: VAC/VAC 14 in reply to Rigidharley, 01-05-2004 07:40:25
Thanks for the reply. I have seen pictures of these, and didn't know what they were. I have had a VAC For five years and use it daily for blading and plowing and everyday chores. Seems to be a good tractor; don't think I would change much if I were designing it... Todd
Jim
01-05-2004 20:04:06
 Re: Re: Re: VAC/VAC 14 in reply to Todd, 01-05-2004 13:10:58
Well, I have three, and still use them on the farm. The VAC-14 was CASE's answer to Ford's 8N, but better. The VAC-14 has live hydraulics and opinional remote cyinder equipment, which the ford didn't have. The VAC-14 also had a little more ground clearance, about the same as the regular VAC. The nice thing is if your eagle hitch is complete, you don't even have to get off to hook things up.
bill
01-09-2004 05:45:18
 Re: Re: Re: Re: VAC/VAC 14 in reply to Jim, 01-05-2004 20:04:06
Speaking of which, my eagle hitch is missing the upper claw on one side. Got a home made unit but have to manually mess with it when changing over. Any idea where I can locate a claw?
Jim
01-09-2004 18:56:56
 Re: Re: Re: Re: Re: VAC/VAC 14 in reply to bill, 01-09-2004 05:45:18
Well, if you need the latch for the claw, they used two differnet styles, and I'd need to know which one to point you in the right direction. If you give me the casting number off of the other side or the bottom part of the claw, I will know which one you have.
Joe (Wa)
01-10-2004 09:40:01
 Re: Re: Re: Re: Re: Re: VAC/VAC 14 in reply to Jim, 01-09-2004 18:56:56
Hi Jim, I am interested in this subject, perhaps you can clear this up.
My claws are p/n vt579 on both sides.
Latches are right side vt614 and left side vt615.
Question...will latches p/n vt580 & vt597 fit the above claws?
Thanks, Joe
bill
01-10-2004 03:41:50
Ok, will check for a part number on the one. Can also take a pic and email. Let you know in a few days ( gotta get to camp first)
