990A Implematic hyd
Kalki
01-05-2004 04:11:59
Hi all, My hydraulics work fine when they are cold but drop off badly when hot. I have cleaned the control valves and it made no difference, as the arms do not drop overnight with a heavy load on them I figure the ram seals are fine..Only other option I see is the pump itself but although I have the schemetics for the pump I have nothing on the removal of the pto housing to get to it and I don`t like unpleasent suprises. Would appreciate it if somebody out there could email me the couple of necessary pages from the manual..regards to all
Elmer
01-05-2004 14:24:33
 Re: 990A Implematic hyd in reply to Kalki, 01-05-2004 04:11:59
Just remove the ten bolts from the pto housing and pull it off. There is a dowel pin on the left side of the housing that you may have to fight with.
Kalki
01-06-2004 01:45:23
 Re: Re: 990A Implematic hyd in reply to Elmer, 01-05-2004 14:24:33
Thanks Elmer, if I don`t get the papers at least thats something to go on
