Case tripl range
Myron
01-04-2004 16:50:38
I have found a Case tractor sitting at a cotton gin in Texas. I'm trying to find out what model it is. The plate is missing from the dash, but I found the following #'s on the engine block. 345S07734. The tractor appears to sit closer to the ground than most others and it seems to be very well built.I have been told that it may be a 430 Indusrial with a gas engine. They are asking $400 dollars for it, but I'd like to know what it is before I buy it. How do I find this out? It also says Tripl Range on the side and is missing two grilles in the front. Any help
John Saeli
01-04-2004 18:15:17
 Re: Case tripl range in reply to Myron, 01-04-2004 16:50:38
Holy Cow Myron!! For $400 I'd get it home 1st and ask questions later.
Mike Schotte
01-04-2004 17:09:31
Myron,
You can start by looking around this site. A quick search of the "Tractor Photos" link under "Galleries" shows 13 Case 430 tractor photos, including this one:
third party image
Good luck. Where in Texas is the tractor located?
-Schotte
Mark
01-04-2004 17:33:28
 Re: Re: Case tripl range in reply to Mike Schotte, 01-04-2004 17:09:31
I looked up what little info I have and the story on 430-530-630 in Old Abe's News says that Case perceived a need for a low utility model and the 430 was modified with 24 inch rear wheels (and higher gearing in ring gear to compensate), shorter front spindles and downward exhaust. The Decision Memorandum is dated 10/24/64 and refers to it as a 435. There is also an earlier Decision Memorandum dated 10/28/63 referring to a new "low profile model" with short turning radius and minimum of steering wheel turns lock to lock. These had hydrostatic steering as standard equipment. I see no mention of a true industrial model but that doesn't mean much.
