580 CK B oil change
joe francano
10-01-2006 19:21:32
Hello,
I have a 73 580 CK that is working fine. I have come into a 55 gallon drum of hydraulic R&O fluid. I was thinking of flushing the entire hydraulic system out. The tractor and hoe attachment are kept next to a creek and are in a high humidity environment. I was looking around on the frame and couldnt see a place to drain the fluid from. Is there an alternative to disconnecing a hose and then flushing to a drum?
Thanks for any help.
Phil (NJ,AZ,SASK)
10-01-2006 23:30:14
 Re: 580 CK B oil change in reply to joe francano, 10-01-2006 19:21:32
JOE, On my 530 CK the FEL frame is the TANK and
has a DRAIN under the RH side. I assume you also check & fill the fluid level on the FEL frame.
Hope this Helps,
joe francano
10-02-2006 04:23:51
 Re: 580 CK B oil change in reply to Phil (NJ,AZ,SASK), 10-01-2006 23:30:14
Ill climb under it again. Thanks for the info.
Joseph A Francano III
10-06-2006 07:00:22
 Re: 580 CK B oil change in reply to joe francano, 10-02-2006 04:23:51
There was a plug on the return under the frame. I removed it an let my 10 gallons of joy/water drain out. It was a mess. Glad it was changed. The pump seemed to quiet down now.
